Zenith volume control - 2 tap
12/17/2010 10:38:24 AMjohn s
Zenith 11S474 Ch. 1103
Has anyone come up with a volume control circuit that uses a standard pot (or a pot with 1 tap) that can be used in place of a dual tap pot?
12/17/2010 12:40:37 PMmelrose
A pot with two taps is necessary for all the Radiorgan tone control buttons to function properly due to the design of that circuitry. If you are willing to give that feature up, then a different control could be used.
Some 50's and 60's high fidelity and stereo sets used a 2.5 meg volume control with two taps, electrically identical to the one Zenith specified but physically somewhat different. That's one of the easier sources to find the part you need, if someone has scrapped out a console and saved the control. It's usually possible to modify the shaft on one of those newer controls to fit the shaft coupling on the Zenith chassis.
Also, Mark Oppat may still have some 2.5 meg double tapped controls available.
:Zenith 11S474 Ch. 1103
:Has anyone come up with a volume control circuit that uses a standard pot (or a pot with 1 tap) that can be used in place of a dual tap pot?
:Thanks
12/19/2010 2:10:19 PMTerry Decker
:A pot with two taps is necessary for all the Radiorgan tone control buttons to function properly due to the design of that circuitry. If you are willing to give that feature up, then a different control could be used.
:Some 50's and 60's high fidelity and stereo sets used a 2.5 meg volume control with two taps, electrically identical to the one Zenith specified but physically somewhat different. That's one of the easier sources to find the part you need, if someone has scrapped out a console and saved the control. It's usually possible to modify the shaft on one of those newer controls to fit the shaft coupling on the Zenith chassis.
:Also, Mark Oppat may still have some 2.5 meg double tapped controls available.
::Zenith 11S474 Ch. 1103
::Has anyone come up with a volume control circuit that uses a standard pot (or a pot with 1 tap) that can be used in place of a dual tap pot?
::Thanks
Just a comment. I recently tried to find an audio taper 2 meg pot and Googled every supplier I could find, including Mark, AES, Mouser, etc, etc. Finally, I got a couple from forum members. I have two stereo pots and a single with a defective switch. If any of these will help email me.
Terry
12/19/2010 2:32:28 PMThomas Dermody
Anybody try Playthings of the Past?
You can devise a circuit of fixed resistors. However, there is a reducing effect of the Radiorgan as the volume control is advanced, so that the radio can still be powerful, albeit with more mid-range and harsher tone. This would not occur if the resistor taps were separate from the volume control.
