RCA
12/4/2010 5:39:53 PMCharles
I need a electric schematic of RCA Model 695MX .It had made in Argentina.It has 12BA6,12BE6,12BA6,12av6,36L6 AND 35Z5.Help
Thank you
12/4/2010 6:03:30 PMNorm Leal
Hi Charles
If you don't find an exact schematic may need to search on resources, above.
This RCA may be similar:
http://www.nostalgiaair.org/PagesByModel/077/M0015077.pdf
Tubes like 12SG7 and 12SK7 are electrically similar to 12BA6. 12SA7 is similar to 12BE6. 12SQ7 is similar to 12AV6. Your first 4 tubes are miniature but will use a circuit like octal types.
:I need a electric schematic of RCA Model 695MX .It had made in Argentina.It has 12BA6,12BE6,12BA6,12av6,36L6 AND 35Z5.Help
:Thank you
12/4/2010 6:39:36 PMcharles
:Hi Norm :I have a problem .The second electrolitic condenser has no tension.I change it but the tension is 0 Volt.
0 Volt have the in second grille of 35L6,anode of 12AV6 and anode of 12BA6.
Can you help me? best regards
Hi Charles
: If you don't find an exact schematic may need to search on resources, above.
: This RCA may be similar:
:http://www.nostalgiaair.org/PagesByModel/077/M0015077.pdf
: Tubes like 12SG7 and 12SK7 are electrically similar to 12BA6. 12SA7 is similar to 12BE6. 12SQ7 is similar to 12AV6. Your first 4 tubes are miniature but will use a circuit like octal types.
::I need a electric schematic of RCA Model 695MX .It had made in Argentina.It has 12BA6,12BE6,12BA6,12av6,36L6 AND 35Z5.Help
::Thank you
12/4/2010 9:38:56 PMNorm Leal
Hi Charles
There should be a resistor or speaker field between first and second filter cap. It's most likely open?
::Hi Norm :I have a problem .The second electrolitic condenser has no tension.I change it but the tension is 0 Volt.
:0 Volt have the in second grille of 35L6,anode of 12AV6 and anode of 12BA6.
:Can you help me? best regards
:Hi Charles
:: If you don't find an exact schematic may need to search on resources, above.
:: This RCA may be similar:
::http://www.nostalgiaair.org/PagesByModel/077/M0015077.pdf
:: Tubes like 12SG7 and 12SK7 are electrically similar to 12BA6. 12SA7 is similar to 12BE6. 12SQ7 is similar to 12AV6. Your first 4 tubes are miniature but will use a circuit like octal types.
:::I need a electric schematic of RCA Model 695MX .It had made in Argentina.It has 12BA6,12BE6,12BA6,12av6,36L6 AND 35Z5.Help
:::Thank you
