Common remaining 7 pin tubes are the 50C5, 50B5, 35W4, 35C5, and 35B5. 12AT7, 12AU7, and 12AX7 sometimes show up in radios, too.
There are some other 7 and 9 pin tubes that I can't think of that are sometimes found in radios; most often German radios or other European radio brands.
Usually any tube starting with an 8, 13, 17, 19, 20, 23, or some other numbers I can't think of are usually for series string television use. Almost all compactrons are for television use. The rest, which can fall in any category, you will have learn by experience. For instance, 22DE4 or 6DE4 are octal base tubes, but are best suited as the damper in the flyback circuit of a television, and not for radio use.
I believe that there are a few 9 pin tubes that start with 17 and 19 that are used in the front end of an FM radio, and these tubes are designed for series string use with ordinary .15 ampere radio tubes.
Also, Loktal tubes have aluminum or nickel plate steel or brass bases. Some octal tubes have metal/bakelite bases, and octal tubes can also have an all metal envelope with a bakelite base. The great majority of these tubes were developed for radio use, with some being used also in early television receivers, and a few being specificially designed for television use. The 6BG6, for example, is a 6L6 that has extra plate wattage capacity and a plate connection to the top of the tube instead of pin 3, that was developed for the horizontal output section in magnetically deflected television sets. 6DE4, as was mentioned earlier, is an example of another octal tube designed specifically for television use. Most octal tubes that you will encounter are, however, primarily designed for radio use.
http://www.nj7p.org/Tube.php
This will most times will tell you what the tube application is used for.
Here is a list of radio tubes:
http://personalpages.tds.net/~pdieten/tubes.pdf
You won't go wrong with picking up these.
Some types are used in both radio and TV.
:Thanks all you guys for answering so fast.I have 30s 40s&50s am radios.I,ve been looking at box lots of tubes on e-bay to see if I could use any, but by the numbers I can,t tell if they are radio or tv.Is there way to tell by the numbers? Thanks Ya,ll pass a good time.
