There are plenty of other tubes that make for good use in radio work, as well. One in particular that comes to mind is a smaller triode-pentode type tube, perhaps the 6GH8. The triode makes for a good cathode fed RF input stage for a simple FM radio, and the pentode stage makes a good super regenerative detector. One could also use a 12AT7, but with so many 6GH8 (and variants) being practically thrown away, why pass up a good deal?
:If you are looking to build some of your own projects, however, television tubes make for an excellent and inexpensive source of tubes. For instance, there is an excellent triode-pentode, that comes in a tall 9-pin package that is meant for vertical deflection, that makes an excellent compact audio tube, with both the 1st and 2nd audio in the same package. I forgot the number, and mine are all in storage somewhere, but there are several numbers of equivalent design that work well. I even built a complete push-pull amplifier using just two tubes. Since the tubes are designed for the vertical output circuit of a television, they aren't best suited for audio use. The pentodes have a rather harsh and bright sound. However, with a suitable negative feedback circuit, this can be corrected.
:There are plenty of other tubes that make for good use in radio work, as well. One in particular that comes to mind is a smaller triode-pentode type tube, perhaps the 6GH8. The triode makes for a good cathode fed RF input stage for a simple FM radio, and the pentode stage makes a good super regenerative detector. One could also use a 12AT7, but with so many 6GH8 (and variants) being practically thrown away, why pass up a good deal?
:T.
