:This car is a 6 volt positive ground. To convert to 12 volt negative ground there are things to be considered. All the gauges are 6 volt positive ground. The clock is too. Overdrive solenoid is 6 volt. All lights need to be changed. Dash and radio lights are on rheostat dimmer but need 12 volt bulbs. fuses need to be changed.
: The car should really be kept 6 volt positive ground. There is no problems with 6 volt systems as long as the correct 6 volt battery is used. This car takes a large long battery. 6 volt battery cables are twice the gauge of 12 volt ones. Good clean ground points to body and frame.
