Yours Truely,
Daniel
http://www.wa2ise.com/radios/repair.htm#if
Dear Warren, You are right on the money, I found the 470K ohm resitor, replaced it and the radio began to play. Thank you for the link, I will go there read this and work on the IF Cans. Thank you Kindly for your help!!! Have a great day!
Daniel
:http://www.wa2ise.com/radios/repair.htm#if
Thank you again Warren for all the help. I will post a summary of the project to let you know how it came out.
Daniel
I ate too much at lunch and dinner today and feel bloated, yuck!
::When you are removing the IF transformers be sure to mark everything as to the can to board, and bottom of the insides to can. It is possible to put the insides back together backwards. There is a Primary and secondary winding. You can use 100pf mica disks at 50 volts on the bottom of the IF cans. Across each winding.
:Thank you again Warren for all the help. I will post a summary of the project to let you know how it came out.
:Daniel
Header | |
Left menu Item 1 Item 2 Item 3... | Main body |
Footer |
:I ate too much at lunch and dinner today and feel bloated, yuck!
:::When you are removing the IF transformers be sure to mark everything as to the can to board, and bottom of the insides to can. It is possible to put the insides back together backwards. There is a Primary and secondary winding. You can use 100pf mica disks at 50 volts on the bottom of the IF cans. Across each winding.
::Thank you again Warren for all the help. I will post a summary of the project to let you know how it came out.
::Daniel
::::When you are removing the IF transformers be sure to mark everything as to the can to board, and bottom of the insides to can. It is possible to put the insides back together backwards. There is a Primary and secondary winding. You can use 100pf mica disks at 50 volts on the bottom of the IF cans. Across each winding.
:::Thank you again Warren for all the help. I will post a summary of the project to let you know how it came out.
:::Daniel
:learning to code in html. thanks for the forum to let me play
:::::When you are removing the IF transformers be sure to mark everything as to the can to board, and bottom of the insides to can. It is possible to put the insides back together backwards. There is a Primary and secondary winding. You can use 100pf mica disks at 50 volts on the bottom of the IF cans. Across each winding.
::::Thank you again Warren for all the help. I will post a summary of the project to let you know how it came out.
::::Daniel
