:I bought a EICO 635 TUBE TESTER from eBay and find out it can only test the newer tubes (no earlier than 1939). But I have a 1931 Philco 70, 90 radio that use the older tubes. Can I use some kind of adapter with this tester to test the old tube? or, which inexpensive tube testers you recommend can test most of the old radio tubes from 1930-1950? Thanks in advance!
:Eico 625 & Knight 600 both are 3 position lever sets. The Eico 635 rotary switch set up. Don't see how to use set up chart from 625 for 635 ?
:Know what your saying about that. Have used an old tube base with stiff wires soldered in the pins. Clip leads to the tube under test. One thing to take note of, is how fast the needle climbs. Gives some indication of a more healthy tube.
:I have the Hickoc 800 & the knight 600. Both tested a 12BE6 as good. (no shorts, no gas) in the radio it had modulation hum. Sub in any other 12BE6. The radio works fine. Even the best so called tube testers have there short comings.
::That's why most of us who have been at this for a long time consider tube testers to be our least useful pieces of test gear. Their best use is to determine that a tube is really extremely weak or dead when we don't have another to substitute.
:::I have the Hickoc 800 & the knight 600. Both tested a 12BE6 as good. (no shorts, no gas) in the radio it had modulation hum. Sub in any other 12BE6. The radio works fine. Even the best so called tube testers have there short comings.
:I don't know about that. My 912 has shown inter-element shorts I wouldn't have found otherwise. It tests emission as well as function. Loctal and 9 pin, (with adapter). A bunch of supplement books came with it. I have yet to find a tube it can't test.
:T.
