Johnny
Johnny
Also the radio appears to require more antenna other then the 6' piece of wire that's currently connected to it. I grab this wire and reception increases dramatically. Is this typical of this set? To require some kind of outdoor/indoor longer antenna wire?
Johnny
:Sir Johnny . . . . .
:I guess that the unit merely of yours has what is classified as a log dial scale for the tuning condenser, with
:but a few variants, the usual dial marking was for the 0 being relevant to minimum capacitance settting of the tuning condenser.
:Meaning that the highest frequencies . . .1700 . . . would be received at that end of the condensers setting.
:The 100 was the maximum capacitance of the tuning condenser, and that would have the 540 portion of the BCB coming in.
:On a few versions of tuning capacitors the numbering was reversed.
:Soooooo . . . the idea was for 'ole granny Goodknockers . . . who knew little of this new fangled radio thang. . .to take a #2 lead pencil and pull out a Big Chief tablet and initially locate a received station and hang on long enough for station ID and then the writing down of the "log" number found on the scale, onto the tablet, and its associated station callsign / frequency data.
:Initially one would be seeing pencil marks made on the dial scale proper, for favorites, until the stations were eventually learned.
Go to an auto parts or hardware store and get some rubber hose of the appropriate o.d. and i.d. Slice a tire from it.
