Propeller Dial Pointer
11/9/2010 2:19:34 PMSam Martin
I need a propeller dial pointer for a Y-825 Zenith radio (1956).
This type of radio is quite common. The pointer shaft is 1 1/4
inches long.
11/11/2010 8:44:15 PMMmakazoo
Sam: I have a propeller dial pointer from a Zenith AM/FM radio model G725 / Chassis 7GO1. The length of the part that goes on the shaft is about 3/4 inch long. Metal, sort of a brass plating on it. Maybe I could send a pic for you to look at. Mark from Kalamazoo
11/14/2010 4:09:50 PMsam martin
:Sam: I have a propeller dial pointer from a Zenith AM/FM radio model G725 / Chassis 7GO1. The length of the part that goes on the shaft is about 3/4 inch long. Metal, sort of a brass plating on it. Maybe I could send a pic for you to look at. Mark from Kalamazoo
11/14/2010 4:11:51 PMsam martin
Thanks for the response....
