::HI: Looking for ten of them. thanks
:The highest voltage I have ever heard of for a zener is 200 volts.
:Johnnysan-
FYI:
http://www.datasheetdir.com/Z105B+Zener-Diodes
Those are also available in surface mount type.
Zener diodes or spike suppressors ?
I often see 330V "avalanche diodes" as spike suppressors.
As for availability, you can drop a note to the guys on this link http://www.datasheetdir.com/Z105B+Zener-Diodes;
Extensive Technology Ind. Co., Ltd.
They should be able to direct you to a local source, if any.
Good luck.
There is a reason Zener diodes aren't common in higher voltages. Zener diodes are rated in watts. As voltage increases the diodes handle lower current. At 330 volts drawing only 1 ma is already .33 watts.
Does voltage need regulation? TV's used a 6BK4 tube to regulate high voltage. There are other gas regulator tubes that can be used in series.
