:Well, yes & No. The negative end being disconnected would seem now to be open ended. But what if there is a resistor between any of the positive ends? Like the pie circuit common in AC/DC radios. This would give a false reading.
I have occasionally come across a multi-section where I charged one section and found a charge on another section(s), but technically they are supposed to be isolated.
:Should hopefully be isolated if things haven't gone bad inside. The Solar CB does reform well, as does a lot of other things well including just looking good.
:I have occasionally come across a multi-section where I charged one section and found a charge on another section(s), but technically they are supposed to be isolated.
:T.
