www.nexicom.net/~oidar/rog4621.pdf
Unfortunately the original printed schematic is only 7 inches wide so it may not be all that readable unless you are able to print it larger.
Ed.
:A schematic from the Rogers Service Manual Volume has been posted at--
:www.nexicom.net/~oidar/rog4621.pdf
:Unfortunately the original printed schematic is only 7 inches wide so it may not be all that readable unless you are able to print it larger.
:Ed.
:Thanks for the info :
::A schematic from the Rogers Service Manual Volume has been posted at--
::www.nexicom.net/~oidar/rog4621.pdf
::Unfortunately the original printed schematic is only 7 inches wide so it may not be all that readable unless you are able to print it larger.
::Ed.
