Do this schematic be the right series ? We'uns thinks that you " mis-warred" sumpin' . . . . . and you'se gots to figgers out THOSE types of problems yourselfs. Now: Would you give us the percentage of the "undesirable" level, as being compared to the radio stations audio being tuned in , and is it different on a stronger or a weaker station ? We KNOWS that the station audio will disappear but if the offending noise remains, its vewy likely to be in the AF output stage or else being introduced in from the units power supply.
Sir Jessee. . . . .
http://www.nostalgiaair.org/PagesByModel/170/M0020170.pdf
Go to the 6F6 output and use a pocket size mini screwdrivers blade to short the 1st grid to the cathode and see if that offending noise, IN ADDITION to the received station audio, then disappears.
Try the same shorting out with the 6SQ7, and in its case you can just short across its item #10 1st gridamus ree-sistor.
:Hi all,
: After replacing ALL OF THE CAPS in this radio it has a unreal BUZZING sound.. Not so much like filter caps, but kinda the same.. Radio recieves stations but it just buzzes.. Nothing on around the radio to cause interference, also when volume control is turned it does not increase in vol, just same BUZZING.. Help me please figure out what to look for?
:Hi all,
