To Re-String or Not To Re-String Ref: Stewart warner 11-6u
10/22/2010 8:11:32 AMJesse
After trying to place a new dial cord on second part of drum last night to tighten up and actually make the entire drum move so that pointer would move, the older dial cord came disconnected from its original postion, SO with that being stated and the older dial cord being dry and hard to move and place in it's original postion, Would everyone agree it's time to re-string the entire operation? Also the diagram avail for this radio is not as clear cut and Im having some difficulty in putting the string in the right direction as well as figuring out if the only guides for the pointer string are the two wheels up top on the back face of the radio.. GEEZ, any suggestions?
10/23/2010 2:22:49 AMJohnnysan
:After trying to place a new dial cord on second part of drum last night to tighten up and actually make the entire drum move so that pointer would move, the older dial cord came disconnected from its original postion, SO with that being stated and the older dial cord being dry and hard to move and place in it's original postion, Would everyone agree it's time to re-string the entire operation? Also the diagram avail for this radio is not as clear cut and Im having some difficulty in putting the string in the right direction as well as figuring out if the only guides for the pointer string are the two wheels up top on the back face of the radio.. GEEZ, any suggestions?
Take your time and learn to do the restringing the right way; take notes on the old stringing, and don't do it differently. Take photos. If the restringing gets to be a chore, stop for a while then get back to it--this is a hobby, not a job.
Johnnysan-
10/23/2010 11:02:54 AMJesse
::After trying to place a new dial cord on second part of drum last night to tighten up and actually make the entire drum move so that pointer would move, the older dial cord came disconnected from its original postion, SO with that being stated and the older dial cord being dry and hard to move and place in it's original postion, Would everyone agree it's time to re-string the entire operation? Also the diagram avail for this radio is not as clear cut and Im having some difficulty in putting the string in the right direction as well as figuring out if the only guides for the pointer string are the two wheels up top on the back face of the radio.. GEEZ, any suggestions?
:Take your time and learn to do the restringing the right way; take notes on the old stringing, and don't do it differently. Take photos. If the restringing gets to be a chore, stop for a while then get back to it--this is a hobby, not a job.
:Johnnysan-
