http://www.the-s38-guy.com/Page_2.html
Terry:
Funny you should remind me of:
"I've also made ABSOLUTELY sure that the outlets are wired correctly, and ground goes to the building service ground."
Back in my Delta days, I had an assignment to calibrate a new piece of test equipment using a frequency counter on a bench I usually didn't use. I turned off power to the whole bench using the master switch whenever I was working around "hot" parts of the counter. All of a sudden, there was a sound like an arc welder and a great big ball of fire and smoke came out of a very expensive frequency counter. It later turned out that the idiot (who later made management, of course) that wired the bench put the power switch in the neutral side of the power line, instead of the hot. The bench and all the test equipment was grounded to the ground wire of the power line, so we had a nice little booby trap waiting for some boob (me) to walk into it, which I promptly did. After that, I also made ABSOLUTELY sure that the outlets are wired correctly, and ground goes to the building service ground.
