As an experiment, I hooked up what I believe is one earpiece of a high impedance headset with a DC resistance of about 1100 ohms to the output tube and placed it in the horn. Sounds almost like an authentic horn speaker. Provided it is high impedance is there any problem with this setup? I could likely reduce the output voltage to 90 from 135.
:I have an Atwater Kent horn speaker without a base. At some point I will hopefully find a base or make something that is large enough that I could put a pm speaker and output transformer in it as means to use the horn with my Stewart Warner model 500 TRF radio.
:As an experiment, I hooked up what I believe is one earpiece of a high impedance headset with a DC resistance of about 1100 ohms to the output tube and placed it in the horn. Sounds almost like an authentic horn speaker. Provided it is high impedance is there any problem with this setup? I could likely reduce the output voltage to 90 from 135.
