Can anybody tell me the model number so that I can download the circuit from Nostalgia Air
::I have a Silvertone with the following tube lineup
::6BJ6
::6BJ6
::12BE6
::12AV6
::50C5
::35W4
::The model number is not visible on the identification tag. It has a clock on the side, and provision for plugging something on the back.
::Can anybody tell me the model number so that I can download the circuit from Nostalgia Air
:Hi Anton. It's kind of hard to tell with just a tube line up. Is it AM/FM? Can you post a photo?
:Terry
The point of differentiation on that set is the use of 2 6BJ6's . . . .. didn't find such with a ? Silvertone? Try the possibility of this Garod , since it is using a 6BJ6 tube as an RF amp and also in the IF stage. Sooooooooo . . . check and see if the unit has a 3 section tuning condenser. Also this unit additionally has one short wave band in addition to the common BCB . BUT fron the basic similarity of the schematic design . . . . . . taking note of a "brother" 50B5 being used instead of the akin 50C5 . . .u just might be able to work with it.
:6BJ6
:6BJ6
:12BE6
:12AV6
:50C5
:35W4
Never knew radios made coffee as well!!
:Sir Anton. . . . .
:The point of differentiation on that set is the use of 2 6BJ6's . . . .. didn't find such with a ? Silvertone?
:but if one ignores the mere simplicity of a clocks timer actuation / switching.
:Try the possibility of this Garod , since it is using a 6BJ6 tube as an RF amp and also in the IF stage.
:Sooooooooo . . . check and see if the unit has a 3 section tuning condenser.
:Also this unit additionally has one short wave band in addition to the common BCB .
:BUT fron the basic similarity of the schematic design . . . . . . taking note of a "brother" 50B5 being used instead of the akin 50C5 . . .u just might be able to work with it.
::6BJ6
::6BJ6
::12BE6
::12AV6
::50C5
::35W4
:: :: :: If it helps the chassis number is 132 022 :: :: :: ::Sir Anton. . . . . :: :: :: ::The point of differentiation on that set is the use of 2 6BJ6's . . . .. didn't find such with a ? Silvertone? ::but if one ignores the mere simplicity of a clocks timer actuation / switching. :: :: :: ::Try the possibility of this Garod , since it is using a 6BJ6 tube as an RF amp and also in the IF stage. :: :: :: ::Sooooooooo . . . check and see if the unit has a 3 section tuning condenser. :: :: :: ::Also this unit additionally has one short wave band in addition to the common BCB . :: :: :: ::BUT fron the basic similarity of the schematic design . . . . . . taking note of a "brother" 50B5 being used instead of the akin 50C5 . . .u just might be able to work with it. :: :: :: :: ::> > > < < < :: :: :: :: :: :: :: ::73's de Edd :: :: :: ![]() :: |
