:::Where can I get a schematic for a Grundig 3165 U? The rubber bands that hold the ferrite bar in its bracket have disintegrated and the leads have all broken off at their soldering lugs....thanx, nb
:::Anybody?
:Neal,
:I found the schematic at justradios.com. They have a vast list of european schematics including your model.
:It will cost a few dollars.
:Mitch
: : : ![]() : : : : : : : :Sir Neal . . . . . : : :How many fine wires were there to break off ?. . . . and apparently fine solid wire, as I would think that Litz would be more pliant to breakage, unless in a tinned area. : : :Now, seems like I can certainly visualize to 4 connections to the ferrite antenna , but possinly 6, if LW band is additionally wired into it. : : :I may come up with its schema, but definitely NO close up photo of that area of concern. : : : : : :73's de Edd : : : ![]() : |
Most humble apologies for the time delay . . .I had initially prepared referencing and misplaced it . . . Should be the same. RF SIGNAL PATH: Your BCB received RF signal is picked up by the ferrite loop antenna proper and signal passes up [Green] mark-up path thru the switch jumper bar on section # 3 switch completing its c-b path, thus getting the tuning condenser RF section into circuit. That’s all of the connectivity that is required to make the unit operational on the BCB. Now, the other mode of operation would be if one additionally wants the use of an external antenna input. In that mode, the FA antenna switch is RELEASED. OVERALL . . . on the terminal connections to the 4 lug terminal board: Looking at the schematic one is seeing 3 coil windings going to a common ground, so that might account for only one connection of the terminal board taking care of the common grounds, thus leaving two terminal lugs for each of the coils and one lug associated with the big trap coil which has to go downstairs to find that 47 pf cap. The Fuscia bar mark ups on the photo are pretty close to the supports ( missing) for the ferrite rod, and if that unit was shipped and the box ever got inverted 180 degrees, I can see the whole rod falling down . . . and go boom. |
::Sir Neal . . . . .
::How many fine wires were there to break off ?. . . . and apparently fine solid wire, as I would think that Litz would be more pliant to breakage, unless in a tinned area.
::Now, seems like I can certainly visualize to 4 connections to the ferrite antenna , but possinly 6, if LW band is additionally wired into it.
::I may come up with its schema, but definitely NO close up photo of that area of concern.
::73's de Edd
:::::Where can I get a schematic for a Grundig 3165 U? The rubber bands that hold the ferrite bar in its bracket have disintegrated and the leads have all broken off at their soldering lugs....thanx, nb
:::::Anybody?
:::Neal,
:::I found the schematic at justradios.com. They have a vast list of european schematics including your model.
:::It will cost a few dollars.
:::Mitch
:Well, the ferrite rod itself is only 4 inches long, it has two regular coils wired in series, about an inch apart over the middle, and a honeycomb coil close to the end: |-HHH-| |-VVVVV------VVVVV-|
:Only 4 leads, but only 4 lugs to hook onto; no room on the ferrite bar for more coils, so I do not believe any coils are missing. You are correct, it's enamel coil wire, 28 gage, all broke off at the solder joint. Thoughts?
