Heathkit tube oscilloscope 10-10
10/15/2010 11:15:11 AMJON C.
I need info on the Heathkit / daystrom oscilloscope 10-10 It is extemely hard to find the operation manual. I get a horizontal line but no vertical deflection of the beam. I am a beginer on oscilloscopes and am not sure how to trigger this also.
10/15/2010 12:01:47 PMBob Masse
:I need info on the Heathkit / daystrom oscilloscope 10-10 It is extemely hard to find the operation manual. I get a horizontal line but no vertical deflection of the beam. I am a beginer on oscilloscopes and am not sure how to trigger this also.
:Hi! I've got a copy of an assembly manual for an IO-10. Next time you post fill in the E-Mail box and I'll email it to you.
Bob Masse
10/15/2010 2:18:21 PMJon C.
Thanks for the offer of an IO - 10 thats eye oh ten
My oscilloscope is an older ten - ten all tube model
10/16/2010 5:56:31 PMEdd
Sir Jon. . . . .
Methinks that the model number in question is the EYE-OH-10, probably, just the way that their selected font was making that unit read out as.
Thank goodness that it was not 20-30 yrs later vintage and running up against a dot matrix printer.
It was a 3 inch unit from the sixties and if you will check its tube line up, you should find it using :
6X4
1V2
OA2
OC2
(3) 6BS8's
(2)12BH7's
(2)12AU7's
And the unit is using a 3RP1 . . Three inch kine
As per your comment on "triggering", that units design is a recurrent , free running hoz oscillator and is dependent upon setting that frequency close enough to the incoming waveforms frequency . . . or a multiple or submultiple of it.
Then if a STRONG enough of an external sync input is introduced, it sort of "coaxes" the hoz sweep into coincidence with it.
A triggered sweep unit . . . this unit is NOT . . . so one won't be setting up triggering in order to see a .2us risetime on a waveform . . nor its like fall time.
If this is your unit I can fill you in on the rudimentary basics of the units operation, if you can merely supply the front controls labeled markings.
Finally, the IO-10 unit should look'a lik a' this:
:Thanks for the offer of an IO - 10 thats eye oh ten
:My oscilloscope is an older ten - ten all tube model
10/17/2010 4:21:30 PMJon C.
:Sir Jon. . . . .
:Methinks that the model number in question is the EYE-OH-10, probably, just the way that their selected font was making that unit read out as.
:Thank goodness that it was not 20-30 yrs later vintage and running up against a dot matrix printer.
:It was a 3 inch unit from the sixties and if you will check its tube line up, you should find it using :
:6X4
:1V2
:OA2
:OC2
:(3) 6BS8's
:(2)12BH7's
:(2)12AU7's
:And the unit is using a 3RP1 . . Three inch kine
:As per your comment on "triggering", that units design is a recurrent , free running hoz oscillator and is dependent upon setting that frequency close enough to the incoming waveforms frequency . . . or a multiple or submultiple of it.
:Then if a STRONG enough of an external sync input is introduced, it sort of "coaxes" the hoz sweep into coincidence with it.
:A triggered sweep unit . . . this unit is NOT . . . so one won't be setting up triggering in order to see a .2us risetime on a waveform . . nor its like fall time.
:If this is your unit I can fill you in on the rudimentary basics of the units operation, if you can merely supply the front controls labeled markings.
:Finally, the IO-10 unit should look'a lik a' this:
:OK Everybody is right there is no ten ten but IO - 10. So I am planning on inputting a 6.3 volt signal off a line transformer, then all I have to do is input a strong 60 hz signal into the ext sync. Right? How strong is strong its in volts right? Can I just input the 6.3 v transformer signal into both?
::Thanks for the offer of an IO - 10 thats eye oh ten
::My oscilloscope is an older ten - ten all tube model
10/18/2010 1:56:35 AMCarl
This website lists a model 10-10.
http://www.vintage-radio.info/heathkit/index.htm
10/18/2010 10:47:18 AMJon C.
:This website lists a model 10-10.
:http://www.vintage-radio.info/heathkit/index.htm
Yes this is the website made me think there was a 10-10 I found out it is IO-10 eye oh ten./
Now I hooked up,my oscilloscope and get a dot or horizontal line but cannot get any vertical deflection whatsoever. 1st I am going to check the vertical tubes on my tube tester.
10/18/2010 12:48:19 PMCarl
It is 10-10, not IO-10. The IO-XX nomenclature was used for the more modern units. The real question is if the schematic is the correct one.
::This website lists a model 10-10.
::http://www.vintage-radio.info/heathkit/index.htm
:Yes this is the website made me think there was a 10-10 I found out it is IO-10 eye oh ten./
:Now I hooked up,my oscilloscope and get a dot or horizontal line but cannot get any vertical deflection whatsoever. 1st I am going to check the vertical tubes on my tube tester.
10/21/2010 11:55:35 AMBob Masse
:It is 10-10, not IO-10. The IO-XX nomenclature was used for the more modern units. The real question is if the schematic is the correct one.
:::This website lists a model 10-10.
:::http://www.vintage-radio.info/heathkit/index.htm
: Hi!
I checked that schematic and it is the same as for the IO-10. So someone just got confused on the model number.
Bob Masse
