G.E. 202, sure i blew the 12SG7
10/3/2010 8:53:36 PMMitch(88987:0)
All,
Tested the tube on my tube tester and am sure i tested it wrong and burned it out. Radio used to play, reinserted tube, no stations. Removed antenna and tested pin 8 with VTVM, reading 89 Vdc. Heater is ok. nothing on pin 3,4,5.
Comments?
Mitch
10/3/2010 9:17:32 PMTerry Decker(88990:88987)
:All,
:Tested the tube on my tube tester and am sure i tested it wrong and burned it out. Radio used to play, reinserted tube, no stations. Removed antenna and tested pin 8 with VTVM, reading 89 Vdc. Heater is ok. nothing on pin 3,4,5.
:Comments?
:Mitch
Ha ha
For a start use your ohmmeter and check for shorts between the elements.
I have a big sign taped inside the top of my tube tester. It reminds me to check all settings before inserting the tube.
10/4/2010 12:25:52 AMWarren(88995:88990)
You can try a 12SK7 for a sub for now. See if your radio still works.
10/4/2010 1:08:04 AMMitch(88996:88995)
:You can try a 12SK7 for a sub for now. See if your radio still works.
12SK7 did not make any changes.
I will wait for the new tube and post.
Mitch
