Best Regards,
Bill Grimm
Beginning in 1947 Sylvania and RCA both used open date codes for week and year. "7-26" would be the 26th week of 1947. 13, 26, 39 and 52 usually indicate that the code only changed once per quarter.
All the Best,
Bill Grimm
1LD5 is used as 1st audio amplifier in battery radios. Tubes used in this position, in battery radios, will all be microphonic to some extent.
Tubes have a filament wire which is held tight by a small spring. Due to high gain between this tube and speaker there will be microphonic sound when this tube is tapped.
It becomes a problem when speaker vibrations causes a continous ringing sound. Extent of microphonics will change with different tubes but 1U5, 1S5, 1H5, 1LH5 will also give this noise.
:Hi All,
: I have a TO Clipper here full of loctal tubes. Each has a funny little code below the part number. The schematic indicates that this is a date stamp of some kind. It says that 1LD5 with date codes before 'F6E' June 1946 have microphonc problems. I have some microphonc problems.
: I was wondering how one reads these date codes. Does anyone know?
:Best Regards,
:Bill Grimm
:Hi Bill
: 1LD5 is used as 1st audio amplifier in battery radios. Tubes used in this position, in battery radios, will all be microphonic to some extent.
: Tubes have a filament wire which is held tight by a small spring. Due to high gain between this tube and speaker there will be microphonic sound when this tube is tapped.
: It becomes a problem when speaker vibrations causes a continous ringing sound. Extent of microphonics will change with different tubes but 1U5, 1S5, 1H5, 1LH5 will also give this noise.
::Hi All,
:: I have a TO Clipper here full of loctal tubes. Each has a funny little code below the part number. The schematic indicates that this is a date stamp of some kind. It says that 1LD5 with date codes before 'F6E' June 1946 have microphonc problems. I have some microphonc problems.
:: I was wondering how one reads these date codes. Does anyone know?
::Best Regards,
::Bill Grimm
All the Best,
Bill Grimm
