I am trying to troubleshoot a non working tube tester. All parts look to be good (resistors, caps (?), tubes, transformer), but I can't calibrate it. No good voltages retrieved (on octal socket) when pressing push-buttons on calibration procedure. When probing rectified voltage on 83 and 5y3 tubes, I have ~160V DC and about 80 V AC. This don't look good (?).
The schematic is difficult to understand. I can't really find a reference point to proble voltages. I don't really know what to do.
Help please...
Best Regards,
Bill Grimm
What is the acceptable margin of error when reading a voltage in the calibration procedure?
Once you have a tube set up and running, pay attention to the line voltage adjustment and get it right. Higher filament wattage tubes are especially subject to this. This being done, you can test known good ones against whatever you have, and give a verdict. So long as there are no shorts, gassiness, or bizzare results, a low reading should not be an automatic death sentence for a tube.
:That's right... I thought I had properly cleaned all sockets, but they are still intermittants. Will have to replaced them.
:What is the acceptable margin of error when reading a voltage in the calibration procedure?
Why do I have to use a Simpson 260? My Fluke our my Radio Shack (Micronta) can't do the job? Not shure to understand why.
Else, can I use an old Amproble volt-ohm-milliameter or at least my scope?
Thank you.
:Forgot to mention, a Simpson 260 can be made into a 1000 ohms-per-volt meter by shunting it with 250K on the 250V range. Then the plate voltage should be 150V and the screen 130V. Grid bias is 0-40V with an AC signal on top of it.
Hickoks also are calibrated for a 1000 ohms-per-volt meter (which draws 1 mA). If you use a more sensitive meter, the voltages will be higher since the meter isn't loading them down.
The only things to do now, it's to clean all sockets (finish the job I started) and fine tune the 6000 and 15000 ranges, but I don't have any reference tube to see if 3000 range is ok!
:It's possible. You can swap it with the 83 in the tester to find out.
