Truetone D1035 Battery Radio
9/20/2010 1:07:58 PMJoe
Hello
Does anyone have a schematic and alignment information for a Truetone D1035? It is a battery radio (single band) with the following tubes: 3Q5, 1H5, 1A7, & 1N5
Thanks in advance
9/20/2010 1:41:55 PMEdd
Sir Joe. . . . .
Just see if its Siamese twin will work equally as well for you:
> > > HOT LINK to . . . Schematic and Alignment Info . . . < < <
:Hello
:Does anyone have a schematic and alignment information for a Truetone D1035? It is a battery radio (single band) with the following tubes: 3Q5, 1H5, 1A7, & 1N5
:Thanks in advance
9/21/2010 6:00:58 PMTerry Decker
:Sir Joe. . . . .
:Just see if its Siamese twin will work equally as well for you:
:> > > HOT LINK to . . . Schematic and Alignment Info . . . < < <
Edd- you ARE the man! Where'd you come up with that? Just wondering 'cause I searched two data bases and came up with that model but different schematics.
Terry
::Hello
::Does anyone have a schematic and alignment information for a Truetone D1035? It is a battery radio (single band) with the following tubes: 3Q5, 1H5, 1A7, & 1N5
::Thanks in advance
9/24/2010 2:37:49 PMJoe
::Sir Joe. . . . .
::Just see if its Siamese twin will work equally as well for you:
::> > > HOT LINK to . . . Schematic and Alignment Info . . . < < <
::73's de Edd
::73's de Edd
:Edd- you ARE the man! Where'd you come up with that? Just wondering 'cause I searched two data bases and came up with that model but different schematics.
:Terry
:::Hello
:::Does anyone have a schematic and alignment information for a Truetone D1035? It is a battery radio (single band) with the following tubes: 3Q5, 1H5, 1A7, & 1N5
:::Thanks in advance
9/24/2010 2:39:12 PMJoe
Thanks Edd
I'll check it out when I go home. (I have to use the internet at the library.)
73
Joe
::Sir Joe. . . . .
::73's de Edd
::73's de Edd
:Terry
:::Hello
9/25/2010 11:35:17 AMJoe
Well, Its just trivia now, but here is the information:
TRUETONE MODEL D1035
C. R. T. FACTORY No. W41-B4
WESTERN AUTO STORES
On the license label the dominant number is D-234873
The D1135 shematic will most likely work just fine!
Thanks for the help
:Thanks Edd
:I'll check it out when I go home. (I have to use the internet at the library.)
:73
:Joe
:::Sir Joe. . . . .
:::Just see if its Siamese twin will work equally as well for you:
:::> > > HOT LINK to . . . Schematic and Alignment Info . . . < < <
:::73's de Edd
:::73's de Edd
::Edd- you ARE the man! Where'd you come up with that? Just wondering 'cause I searched two data bases and came up with that model but different schematics.
::Terry
::::Hello
::::Does anyone have a schematic and alignment information for a Truetone D1035? It is a battery radio (single band) with the following tubes: 3Q5, 1H5, 1A7, & 1N5
::::Thanks in advance
9/21/2010 12:28:30 PMTerry Decker
:Hello
:Thanks in advance
My Universal schematic locator shows that model in Rider's volume 11-pages 3 and 5. However, the schematics are nothing like you describe. Are you sure that is the correct model number?
Terry
9/24/2010 2:31:08 PMJoe
::Hello
::Thanks in advance
:My Universal schematic locator shows that model in Rider's volume 11-pages 3 and 5. However, the schematics are nothing like you describe. Are you sure that is the correct model number?
:Terry
