Stark 9-66 neon lamp (for short test)
9/17/2010 4:20:30 PMJ-F
Someone know what is the type # for this lamp? I have to replace it... This lamp is bayonette not screw model.
Thanks.
9/17/2010 5:09:56 PMNorm Leal
Hi
How large is the base? If it's like a #47 lamp use NE-51. NE-49 has the same size base but is taller. Larger base with two contacts on the bottom NE-16, NE-48 or a 991 tube will work. A 991 is just a neon lamp with tightly controled operating voltage, used as reference.
:Hi,
:Someone know what is the type # for this lamp? I have to replace it... This lamp is bayonette not screw model.
:Thanks.
9/17/2010 8:51:18 PMJ-F
For now, I know I have a fuse lamp #81 and a pilot lamp #47. The neon lamp look like the #81 but has 2 contacts on the bottom (there is 2 wires under the socket, not like #81 that has 1 wire on the side and 1 under).
The only info I have is: "the neon lamp is a G.E. 1/4 watt, 105-125 volts, candelabra base".
What mean candelabra?
Are the model numbers you wrote on your reply are still good replacement?
Thank you!
:Hi
: How large is the base? If it's like a #47 lamp use NE-51. NE-49 has the same size base but is taller. Larger base with two contacts on the bottom NE-16, NE-48 or a 991 tube will work. A 991 is just a neon lamp with tightly controled operating voltage, used as reference.
9/17/2010 11:30:59 PMEdd
Sir J-F . . . . . .
Looks like you are in the market for an old discontinuated-ed Ne 48 lamp, if using that medium candelabra double button pin base.
Was your old one missing, bwoke, or just won't fire ?
In the newer replacement series, mostly all made by furriners, they are using a clear lucite shell instead of the glass, and it is renumbered as being a B9A.
Unless, you can find some New Old Stock units of the NE48.
For an even MORE positive confirmation of that unit . . . here is its . . . .
Datter sheet:
:For now, I know I have a fuse lamp #81 and a pilot lamp #47. The neon lamp look like the #81 but has 2 contacts on the bottom (there is 2 wires under the socket, not like #81 that has 1 wire on the side and 1 under).
:The only info I have is: "the neon lamp is a G.E. 1/4 watt, 105-125 volts, candelabra base".
:What mean candelabra?
:Are the model numbers you wrote on your reply are still good replacement?
:Thank you!
::Hi
:: How large is the base? If it's like a #47 lamp use NE-51. NE-49 has the same size base but is taller. Larger base with two contacts on the bottom NE-16, NE-48 or a 991 tube will work. A 991 is just a neon lamp with tightly controled operating voltage, used as reference.
9/18/2010 7:15:50 PMJ-F
Well, the lamp is broken and was stuck in socket. Today I managed to detach it from socket and I saw it was a RCA991...
Will look for that type or maybe NE-48...
