gr 711, transistor radio
9/15/2010 1:03:57 PMquini60
Hi,I need this diagram please. thanks
Quini
9/17/2010 11:50:10 PMEdd
Sr Quini . . . . . .sesenta
Now isn't that a little Global unit ?
Same Same . . Like:
Since that sets problem is very likely just going to be the four electrolytic caps dried out . . . see if you can work with this suppled info:
Setenta y treses de Edd
. . . Su Schematica . . .
:Hi,I need this diagram please. thanks
:Quini
9/21/2010 8:11:54 AMquini60
Hi Edd, I will test capacitors, but I think the tanden wrong. The diagram does not open. Thanks, Thanks.
Quini
9/21/2010 5:17:48 PMEdd
Sr "Quini". . . . . .
With your:
but I think the " tanden " wrong. The diagram does not open.
And then, by my using Espanol logic, and kicking into full translation mode, I now see that you were THINKING that the photo depiction of the unit was ADITIONALLY being hot linked, but I see that you then scrolled down and found the schematic existing separately at the very bottom of the post.
:Hi Edd, I will test capacitors, but I think the tanden wrong. The diagram does not open. Thanks, Thanks.
:Quini
