I did a bad bid on Ebay. I bought a Stark 9-66 in bad shape. Clean outside but a bit rusty inside. I know this tester will work with a lot of time spend on it.
But for now I have 2 ceased pots. The one for shorts and the one for bias. I tried electronic cleaner and lubricant. Usually it works, but not today. I can't turn any of these pots. And I do not want to break them by applying too much force.
What can I do?
Thank you.
Anyway, if you can remove the potentiometer and soak with P-B Blaster, and if this doesn't free up the control, try heating the bushing with narrow torch flame or the barrel of a soldering iron strapped to it. Heat quickly, and try to avoid burning the phenolic or the resistance material inside. Heat the bushing until it smokes, and this will surely drive penetrating oil through it and break loose any solids.
Thanks DeoxIT! :)
