:I was wondering if someone could explain to me what a floating ground is verses a chassis ground? I am working on a Meissner 9-1085 AM/SW radio. Any help or ideas will be very greatful!! Thank you!
:Dan
:It means the circuit common (most negative point of power supply) is not connected directly to the metal chassis. It is common to connect the two together with a network, such as a large resistor in parallel with a small cap, to help reduce hum and noise.
::I was wondering if someone could explain to me what a floating ground is verses a chassis ground? I am working on a Meissner 9-1085 AM/SW radio. Any help or ideas will be very greatful!! Thank you!
::Dan
