Do you have any info, model, part #, color code for wires, any resistive values? Can you get the tanks open for visiual? Do you know where the coils came from?
Perhaps with more info we can all find an answer for you.
This is a great Forum.
Mitch
::Hello all, suppose you have a unknown set of coils (oscillator and antenna) with three band capabitity, and you dont have the wiring diagram. Is there a method to identify the windings? Best regards, Meyer
:Meyer
:Do you have any info, model, part #, color code for wires, any resistive values? Can you get the tanks open for visiual? Do you know where the coils came from?
:Perhaps with more info we can all find an answer for you.
:This is a great Forum.
:Mitch
In either case, the lowest frequency of the three bands / coils will have the MOST turns on its largest winding. (Considering a much fewer turns, small tickler winding(s) possibly being involved.) |
:The higher frequency coils will have fewer turns. Or you can measure the coil inductance with a meter.
:Sir Meyer. . . . . .
:There is one whole bunch of qualifying info yet to be supplied.
:Mo' bettah answer . . . .accompanying mo' bettah exploratory info.
:Like . . . is this unit soooo ooooold that the coils are even wound on socketed plug in coil forms.
:Or . . . . are the antenna / and / oscillator coils wound upon . . . possibly . . .a 3/4---1 inch wax impregnated cardboard / phenolic coil form with 3 windings side by side.
:In either case, the lowest frequency of the three bands / coils will have the MOST turns on its largest winding. (Considering a much fewer turns, small tickler winding(s) possibly being involved.)
:As far as which is oscillator coil / versus antenna coil you see if the loop antenna or (antenna connection on older units) is being routed into which coil, and that will be the antenna associated coil.
:As far as the oscillator coil, check your tube used for the mixer or a separate oscillator tube and see which coils wiring is ending up routed to the 1st grid(s) circuitry of that tube.
:Orrrrrrr, if you have a working receiver, switch to Broadcast band , tune in a station and put some thumb and index finger flesh around the larger coil winding, now, on the oscillator coil, that added capacitance should shift the tuning off from the station.
:That coil cluster will be the oscillator coils for the three bands. Same procedure for the other bands, HOWEVER, acquiring reception on the shortwave spectrum seems to be picky, frequency and time related nowadays.
::The higher frequency coils will have fewer turns. Or you can measure the coil inductance with a meter.
:In either case, the lowest frequency of the three bands / coils will have the MOST turns on its largest winding. :
:Edd: I think that's what I said - except the opposite: the higher frequency coils have FEWER turns.
::In either case, the lowest frequency of the three bands / coils will have the MOST turns on its largest winding. :
::73's de Edd
:::The higher frequency coils will have fewer turns. Or you can measure the coil inductance with a meter.
