They have original brass knurled nuts for equipment use in the screw and nut section - VERY cheap!!
Lou
:Hi all ...I have a beautiful 1923 Westinghouse RC unit that I bought with brass base tipped RCA UV201 tubes..and the dam thing still works...ALL ORIGINAL..The only problem is that I am missing one of the binding post nuts on the back...Would anyone have this as a junk part I could swap or buy?? ALSO I am looking for in good condition the two separate Westinghouse RA and DA units...
:I have seen them at my hardware store, Ace Hardware.
:They have original brass knurled nuts for equipment use in the screw and nut section - VERY cheap!!
:Lou
::Hi all ...I have a beautiful 1923 Westinghouse RC unit that I bought with brass base tipped RCA UV201 tubes..and the dam thing still works...ALL ORIGINAL..The only problem is that I am missing one of the binding post nuts on the back...Would anyone have this as a junk part I could swap or buy?? ALSO I am looking for in good condition the two separate Westinghouse RA and DA units...
Since they are on the back of the set, might just use a plain hex nut with the same threads?
:Lou... I know exactly what you are refering to ..the original is not that type.
