You might try the antique TV forum at antiqueradios.com and videokarma.org.
Just so you don't think I'm a nut, the first thing I did was to Google that same as you did. I spent a couple of days following up all the links. The problem is that this seems to be all for older tubes (40's into the 70's) with almost nothing listed for the newer monitor CRT's. I already have the older information and need some of the newer stuff. Thanks for the come back. Brendan
Brendan,
Don't know if this will help, but this site above is involved with computer monitor repair.
You could try here:
http://tdsl.duncanamps.com/tubesearch.php
:I've been working on radio's and electronics for a long time. My grandson has gotten into fixing and restoring old Acrage games (70's,80's, 90's.). Many of these have weak CRT's. I suggested using my RCA WT-333B tester/rejuvrnator. to bring them back to life. I have a lot of the adaptors for this, but many of them don't fit the newer tubes (or are wired incorrectly). Does anyone know where I can find CRT base diagrams on the web? Or if there is a book we can buy? Then we could just use clip leads. Thanks! Brendan
As far as their end terminated clip leads, the only ones that I would trust as being small enough, would be the Pomona or its knock off variants of E-Z clips Lastly what we . . . . really, really, REALLY want ( . . . . . . a la Spice Girls ) is the probably few kine numbers of the kines that you will ACTUALLY be involved with. Thassit . . . |
::I've been working on radio's and electronics for a long time. My grandson has gotten into fixing and restoring old Acrage games (70's,80's, 90's.). Many of these have weak CRT's. I suggested using my RCA WT-333B tester/rejuvrnator. to bring them back to life. I have a lot of the adaptors for this, but many of them don't fit the newer tubes (or are wired incorrectly). Does anyone know where I can find CRT base diagrams on the web? Or if there is a book we can buy? Then we could just use clip leads. Thanks! Brendan
:Hi Brendan
: You could try here:
:http://tdsl.duncanamps.com/tubesearch.php
: Norm
