Resistance reading on old schematic
8/30/2010 6:41:12 PMCarey
On a 1938 Silvertone Schematic many of the resistors
value numbers are followed by the letter "M". Did
they use M instead of K back then? Example R16=31M
8/30/2010 7:32:57 PMMitch
:On a 1938 Silvertone Schematic many of the resistors
:value numbers are followed by the letter "M". Did
:they use M instead of K back then? Example R16=31M
8/30/2010 8:59:20 PMCarey
::On a 1938 Silvertone Schematic many of the resistors
::value numbers are followed by the letter "M". Did
::they use M instead of K back then? Example R16=31M
:Carey,
:I am new to old radio repair as of today, i used to repair them years ago for a living. It's a hobby now.
:If you check the side reference notes on the schematic you should see a reference to the M as 1000 ohms. 31M = 31K ohms (31,000 ohms). With no M it is just ohms. The schematic will call out MEG. ohm values if it is a meg ohm resistor. If you are unsure remove the resistor and measure it out of the circuit.
:Mitch
8/30/2010 9:00:37 PMCarey
:::On a 1938 Silvertone Schematic many of the resistors
:::value numbers are followed by the letter "M". Did
:::they use M instead of K back then? Example R16=31M
::Carey,
::I am new to old radio repair as of today, i used to repair them years ago for a living. It's a hobby now.
::If you check the side reference notes on the schematic you should see a reference to the M as 1000 ohms. 31M = 31K ohms (31,000 ohms). With no M it is just ohms. The schematic will call out MEG. ohm values if it is a meg ohm resistor. If you are unsure remove the resistor and measure it out of the circuit.
::Mitch
Thanks so much... I really appreciate your help..
8/30/2010 9:33:47 PMmitch
::::On a 1938 Silvertone Schematic many of the resistors
::::value numbers are followed by the letter "M". Did
::::they use M instead of K back then? Example R16=31M
:::Carey,
:::I am new to old radio repair as of today, i used to repair them years ago for a living. It's a hobby now.
:::If you check the side reference notes on the schematic you should see a reference to the M as 1000 ohms. 31M = 31K ohms (31,000 ohms). With no M it is just ohms. The schematic will call out MEG. ohm values if it is a meg ohm resistor. If you are unsure remove the resistor and measure it out of the circuit.
:::Mitch
:Thanks so much... I really appreciate your help..
Carey,
Did not see your response!
Mitch
8/31/2010 9:47:03 AMCarey
:::::On a 1938 Silvertone Schematic many of the resistors
:::::value numbers are followed by the letter "M". Did
:::::they use M instead of K back then? Example R16=31M
::::Carey,
::::I am new to old radio repair as of today, i used to repair them years ago for a living. It's a hobby now.
::::If you check the side reference notes on the schematic you should see a reference to the M as 1000 ohms. 31M = 31K ohms (31,000 ohms). With no M it is just ohms. The schematic will call out MEG. ohm values if it is a meg ohm resistor. If you are unsure remove the resistor and measure it out of the circuit.
::::Mitch
::Thanks so much... I really appreciate your help..
:Carey,
:Did not see your response!
:Mitch
:Hey Mitch: I'm new to this site and probably messed up. However, I am back in the Silvertone this morning
thanks to your information. Like a fella said on here,
"It is a sickness". This thing is going to play or
kill me one...
