8/30/2010 4:38:43 PMGuy Allen(88106:0)
Hello there.Help.Radio no sound except LOW hum with volume all way up.Replaced all caps,tested all tubes.Repaired 2 loose connections.Just started this great hobby and that is as far as I can get.Hard to get point to point meter checking.ANYWAY main question.Does phono need to be pluged up for radio to work???? THANKS, Ya,ll pass a good time
8/30/2010 5:11:57 PMTerry Decker(88107:88106)
:Hello there.Help.Radio no sound except LOW hum with volume all way up.Replaced all caps,tested all tubes.Repaired 2 loose connections.Just started this great hobby and that is as far as I can get.Hard to get point to point meter checking.ANYWAY main question.Does phono need to be pluged up for radio to work???? THANKS, Ya,ll pass a good time
Ha ha
Anyway- It'd be nice to have some more information to answer your question, like is there a switch involved? Sometimes the audio is fed through a Radio/Phono switch. Often this switch is an integral part of the tone arm. It's activated when you move the tone arm from the rest position. In this case, yeah, the phono section would have to be plugged in.
Keep us posted.
Terry
8/30/2010 5:37:57 PMWarren(88109:88106)
This set has a radio/phono switch. In the radio posistion it does not need the phono at all. In the phono posistion, you should get a loud hum if you touch the audio input center conductor.
