http://www.antiqueradios.com/gallery/v/RCA/RCA_Radiola_26.jpg.html
::That's pretty much what mine looks like too, except he's missing the mother-of-pearl knob inlays. Two shades of antiqued copper.
:Thanks Guys.
The high-end Radiola hardware was gold flashed, but was matte, never polished.
Polished brass was way out of fashion in the 1920s. Good for fire engines to give the boys something to do between alarms, but no housewife would put up with it. Nickel plating was "in". You don't see polished brass on 1920s cars, do you?
It's pretty unlikely that the 26 tube cover would age to two different shades, in the center and the surrounding area. And do it exactly the same in every 26 I've ever seen.
:Publicity photos were always retouched, to show up better in printed media, and are not a reliable indicator of original appearance.
:The high-end Radiola hardware was gold flashed, but was matte, never polished.
:Polished brass was way out of fashion in the 1920s. Good for fire engines to give the boys something to do between alarms, but no housewife would put up with it. Nickel plating was "in". You don't see polished brass on 1920s cars, do you?
:It's pretty unlikely that the 26 tube cover would age to two different shades, in the center and the surrounding area. And do it exactly the same in every 26 I've ever seen.
:If one reads original radiola material...it states " To clean and keep brass highly polished to gold luster..use damp cloth...." ets..etc...
::Publicity photos were always retouched, to show up better in printed media, and are not a reliable indicator of original appearance.
::The high-end Radiola hardware was gold flashed, but was matte, never polished.
::Polished brass was way out of fashion in the 1920s. Good for fire engines to give the boys something to do between alarms, but no housewife would put up with it. Nickel plating was "in". You don't see polished brass on 1920s cars, do you?
::It's pretty unlikely that the 26 tube cover would age to two different shades, in the center and the surrounding area. And do it exactly the same in every 26 I've ever seen.
I've never seen any reference to polishing brass in Radiola literature, but then, most of my old pamphlets are sales brochures, not owner's manuals. Which one did your quote come from?
:I guess I can tell the difference between brass and gold. My Radiola 32 hardware is exactly the same shade as Atwater Kent's (and hasn't tarnished in 80 years). There's no question about Atwater kent's hardware; one of the highlights of a factory tour there was watching the gold bars being dissolved in acid, to make the electroplating solution.
:I've never seen any reference to polishing brass in Radiola literature, but then, most of my old pamphlets are sales brochures, not owner's manuals. Which one did your quote come from?
I don't know if this forum will display photos or not.
[img]http://antiqueradios.com/gallery/d/121792-1/Radiola+32+dial.jpg[/img]
It's only tarnished where the owner's fingers rubbed it near the thumbwheels. Elsewhere, it's gold plated.
http://antiqueradios.com/gallery/d/121795-2/Radiola+26.jpg
:While I'm at it, my Radiola 26 is here:
:http://antiqueradios.com/gallery/d/121795-2/Radiola+26.jpg
