Grebe AC7
8/26/2010 6:26:38 PMJohn
I just got a neat Grebe Synchrophase radio ca 1927. It uses several 201 tubes. I have an Eico 666 tube tester but it won't test these tubes. What tester will test the 201's and, also, what tester will test a UX199 tube?
All of the 201's are mounted on sockets that have spring like action to them. What was the purpose of that. They booble like booble heads when bumped.
8/26/2010 6:42:11 PMNorm Leal
Hi John
Tubes in your Grebe are most likely marked UX201A. These are the same as 01A on EICO 666 obsolete list.
UX199 is same as 99.
Springs is the sockets are there to reduce microphonics. When these tubes are tapped insides vibrate and cause a ringing noise. Spring sockets reduce this.
:I just got a neat Grebe Synchrophase radio ca 1927. It uses several 201 tubes. I have an Eico 666 tube tester but it won't test these tubes. What tester will test the 201's and, also, what tester will test a UX199 tube?
:All of the 201's are mounted on sockets that have spring like action to them. What was the purpose of that. They booble like booble heads when bumped.
8/26/2010 7:08:02 PMJohn
Hi Norm,
Thanks for tube info and I checked all of them. Two were very weak. It had 6 UX201's and 4 checked good. Looks like someone stuck a 201 in the 80 socket.
One more question. What kind of speaker can I use with this radio? Doesn't look like one wouls need a field coil from the schematic.
John
:Hi John
: Tubes in your Grebe are most likely marked UX201A. These are the same as 01A on EICO 666 obsolete list.
: UX199 is same as 99.
: Springs is the sockets are there to reduce microphonics. When these tubes are tapped insides vibrate and cause a ringing noise. Spring sockets reduce this.
::I just got a neat Grebe Synchrophase radio ca 1927. It uses several 201 tubes. I have an Eico 666 tube tester but it won't test these tubes. What tester will test the 201's and, also, what tester will test a UX199 tube?
::All of the 201's are mounted on sockets that have spring like action to them. What was the purpose of that. They booble like booble heads when bumped.
8/26/2010 8:01:16 PMDoug Criner
Weak '01A tubes can be easily rejuvenated since they have thoriated cathodes. You can do this by running their filaments for a while at several volts higher than rated. You can use your tube tester to do this. Best to wire up a 4-pin base and socket with only the filament pins attached so that no other tube elements are connected.
Rejuvenation might take an hour or so.
8/26/2010 8:18:38 PMAlan Douglas
The AC-7 used 26s. The battery model used 01As but no 80. The 80 went into an outboard power supply.
8/26/2010 8:25:55 PMJohn
:The AC-7 used 26s. The battery model used 01As but no 80. The 80 went into an outboard power supply.
8/27/2010 10:01:01 AMNorm Leal
John
Grebe made a battery operated Synchrophase 7 first then the factory took some back and converted them to AC7. Radios are very similar. Biggest difference, AC version uses a 5 pin tube, #27. See if you radio has a 5 pin tube socket for the detector.
Use a high impedance speaker such as RCA 100 series or Atwater Kent E series. A modern PM speaker can be used with an output transformer.
::The AC-7 used 26s. The battery model used 01As but no 80. The 80 went into an outboard power supply.
:Thanks to all for replies. Thanks for the rejuv idea and will try it. I took a closer look and see that my set uses the 201's and no 80 so batt. powered.
:What kind of speaker though? I have an old Peerless. Would that work?
8/27/2010 10:02:11 AMNorm Leal
John
Peerless speaker is fine..
:John
: Grebe made a battery operated Synchrophase 7 first then the factory took some back and converted them to AC7. Radios are very similar. Biggest difference, AC version uses a 5 pin tube, #27. See if you radio has a 5 pin tube socket for the detector.
: Use a high impedance speaker such as RCA 100 series or Atwater Kent E series. A modern PM speaker can be used with an output transformer.
:::The AC-7 used 26s. The battery model used 01As but no 80. The 80 went into an outboard power supply.
::Thanks to all for replies. Thanks for the rejuv idea and will try it. I took a closer look and see that my set uses the 201's and no 80 so batt. powered.
::What kind of speaker though? I have an old Peerless. Would that work?
