RCA Capacitors
8/16/2010 12:26:26 PMChad
Is there a place that I can tell them what model radio I have and just order all the capacitors at once? It is a RCA K80.
8/16/2010 1:32:22 PMTonyJ
Drop an email to Dave at JustRadios.com
Good guy to work with for putting together a kit specifically for your set.
TonyJ
:Is there a place that I can tell them what model radio I have and just order all the capacitors at once? It is a RCA K80.
8/16/2010 7:17:06 PMJesse Hancock
:Drop an email to Dave at JustRadios.com
:Good guy to work with for putting together a kit specifically for your set.
:TonyJ
::Is there a place that I can tell them what model radio I have and just order all the capacitors at once? It is a RCA K80.
8/18/2010 9:50:28 PMPeter G. Balazsy
:I tried using Dave, and got a response that says.. I will gladly put togehter a kit for you, but you need to tell me which ones you need.. So I am confused if he's that good, then why no help when I needed it!
If you have a schematic you can easily make a list of the caps shown there in the parts list and send it to Dave.
If you cannot find a schematic tell Dave and he may be able to sell you one and possibly make up a kit from that.
.. but you'd have to let him know you do not know what caps the set needs until you get a schematic..
8/19/2010 1:41:24 PMVinny
Dave is a real nice guy and very helpful, I order my caps and resistors from him. The only condition is the $15 minimum not counting the postage.
Vinny A.
8/20/2010 8:59:04 PMCarlson
Good grief. Did you expect him come to your house and solder them in for you also? How about learning what you are doing instead of expecting the guy to drop everything and spoon feed you?
8/20/2010 8:59:34 PMCarlson
8/22/2010 10:14:46 AMJesse Hancock
::I tried using Dave, and got a response that says.. I will gladly put togehter a kit for you, but you need to tell me which ones you need.. So I am confused if he's that good, then why no help when I needed it!
:Good grief. Did you expect him come to your house and solder them in for you also? How about learning what you are doing instead of expecting the guy to drop everything and spoon feed you?
8/22/2010 2:24:29 PMMarv Nuce
Naw Jesse, they're beyond help. Even a big rock couldn't cover that much ignorance.
:::I tried using Dave, and got a response that says.. I will gladly put togehter a kit for you, but you need to tell me which ones you need.. So I am confused if he's that good, then why no help when I needed it!
::Good grief. Did you expect him come to your house and solder them in for you also? How about learning what you are doing instead of expecting the guy to drop everything and spoon feed you?
:The Above comment was written by someone who really needs some advice about being in a forum. The person thinks that if they make harsh comments they offend someone, but if they only knew the ignorance they actually showed they would probably go under a rock and HIDE !!!
8/19/2010 12:58:28 AMWarren
Schematic for RCA K80 is here.
http://www.nostalgiaair.org/Resources/513/M0015513.htm
From the parts list, make your own list of all the capacitors needed. Then order.
