Drop 145 Volts at 15w's
8/13/2010 5:22:44 PMBob
Emerson Rider 6-17 model 108, requires a 145v15w line cord resistor. Is there another way others then using large resistors, perhaps with diodes not much room in radio
8/13/2010 5:45:35 PMWarren
Yes Bob there sure is. It is done with an AC capacitor, and a lower watt resistor. Can use an AC diode too. Send me an E-mail, or post yours. I can send you a really cool Excel worksheet how this is done.
8/13/2010 7:50:29 PMPeter G. Balazsy
Here's all the the info you'll need and all about it.
The Excel spreadsheet is at the very bottom in a zip file.
http://www.vintage-radio.com/repair-restore-information/valve_dropper-calcs.html
8/14/2010 12:06:21 AMNorm Leal
Bob
The site Peter mentioned has a good explaniation about line dropping methods.
If you are in the US don't want 145 volt drop. You must be located in a country with 220 volts? If so you will need a 100 watt resistor or other method to drop voltage. 145 X .3 amps = 43.5 watts.
http://www.nostalgiaair.org/PagesByModel/543/M0004543.pdf
:Emerson Rider 6-17 model 108, requires a 145v15w line cord resistor. Is there another way others then using large resistors, perhaps with diodes not much room in radio
