'ole rotted / ratty wiring . . . . tube pins . . that might be the same diameters . . ( questioning those TWO big 'uns ) . . .for supplying pins. battery hook up wiring, along with the need of the two jumpers needed, [ Fucsia and Blue ] in order to complete the two vibrator transformer primary winding end connections to their companion vibrator contacts. contacts burnishment.) On Page Referencing on DC power cord fabrication :
: : : ![]() : : : : : : : :Sir Johnathon. . . . . : : :No problem / challenge in the hookup for the AC power operation of the set. : : :But if you can't locate the 'ole tirty 'fo Chebby roadster that the original car power plug was on, along with its : : 'ole rotted / ratty wiring . . . . : : :Herewith, the required info for the plug connections on it. : : :Don't know if you were wanting to replicate it with a plastic block / molded Bondo plug and possibly using old : :tube pins . . that might be the same diameters . . ( questioning those TWO big 'uns ) . . .for supplying pins. : : :Or if you are merely wanting to know how to connect battery power into P1 plug on the unit, I have drawn in the : : battery hook up wiring, along with the need of the two jumpers needed, [ Fucsia and Blue ] in order to complete : : the two vibrator transformer primary winding end connections to their companion vibrator contacts. : : :( Plus . . . HOPE that a SYNCHRONOUS vibrator of that age will still work, or that will accept a teardown and a : :contacts burnishment.) : : : : :Your additional full tech info for the set resides herewith: : : : :> > > < < < : : : : :On Page Referencing on DC power cord fabrication : : : : ![]() : : :73's de Edd : : : ![]() : |
:: :: :: ![]() :: :: :: :: :: :: :: ::Sir Johnathon. . . . . :: :: ::No problem / challenge in the hookup for the AC power operation of the set. :: :: ::But if you can't locate the 'ole tirty 'fo Chebby roadster that the original car power plug was on, along with its :: :: 'ole rotted / ratty wiring . . . . :: :: ::Herewith, the required info for the plug connections on it. :: :: ::Don't know if you were wanting to replicate it with a plastic block / molded Bondo plug and possibly using old :: ::tube pins . . that might be the same diameters . . ( questioning those TWO big 'uns ) . . .for supplying pins. :: :: ::Or if you are merely wanting to know how to connect battery power into P1 plug on the unit, I have drawn in the :: :: battery hook up wiring, along with the need of the two jumpers needed, [ Fucsia and Blue ] in order to complete :: :: the two vibrator transformer primary winding end connections to their companion vibrator contacts. :: :: ::( Plus . . . HOPE that a SYNCHRONOUS vibrator of that age will still work, or that will accept a teardown and a :: ::contacts burnishment.) :: :: :: :: ::Your additional full tech info for the set resides herewith: :: :: :: ::> > > < < < :: :: :: :: ::On Page Referencing on DC power cord fabrication : :: :: :: ![]() :: :: ::73's de Edd :: :: :: ![]() :: |
