1. This radio has a 6N6G power triode. I have not tested it yet but where can I get a replacement if I need to replace it? Is is hard to find?
2. Also there is cap, C32, that is mounted inside a metal box (~1/2 X 1/2 X 1.5 Inches) soldered to the side of the chassis. It is a 1000V .012uf. Can a 630v of same value replace that? Or where can I get a replacement?
3. Do Filter caps C17 and C36 negative side connect to chassis ground? While C33 to the center tap of the TX?
Thanks for any help you can provide.
Bob E
The 6N6G is common and readily available from many tube suppliers..some listed:
vacuumtubesinc.com ; NOS-$28.50, used-$14
findatube.com ; NOS-$12, used-$7
I have used vacuumtubesinc many times with no problems.
Have not bought from findatube yet but his prices seem to be the least expensive around.
:2. Also there is cap, C32, that is mounted inside a metal box (~1/2 X 1/2 X 1.5 Inches) soldered to the side of the chassis. It is a 1000V .012uf. Can a 630v of same value replace that? Or where can I get a replacement?
A common .01 uf at 630V will be fine. I would install a fuse after the power switch and a polarized plug.. make sure you switch the hot side of the A.C. for safety.
:3. Do Filter caps C17 and C36 negative side connect to chassis ground? While C33 to the center tap of the TX?
:Thanks for any help you can provide.
:Bob E
Yes, correct. A good source of caps. is justradios.com in Canada. He is reliable and easy to deal with. John
A comment about 6N6G. This tube has a built in resisor that can't be tested. Over time it can increase in value and allow the tube to draw a lot of current.
Even though way different, looking at a tube diagram, it can be replaced by 6F6, 6V6 etc. Just grid bias needs to be added. This can be done by inserting a 470 ohm @ 1 watt or greater resistor in series with wire going to pin #8. Bypass the resistor with 25 mf @ 25 volt electrolytic cap.
:Schematic http://www.nostalgiaair.org/PagesByModel/113/M0017113.pdf
::1. This radio has a 6N6G power triode. I have not tested it yet but where can I get a replacement if I need to replace it? Is is hard to find?
:The 6N6G is common and readily available from many tube suppliers..some listed:
:vacuumtubesinc.com ; NOS-$28.50, used-$14
:findatube.com ; NOS-$12, used-$7
:I have used vacuumtubesinc many times with no problems.
:Have not bought from findatube yet but his prices seem to be the least expensive around.
::2. Also there is cap, C32, that is mounted inside a metal box (~1/2 X 1/2 X 1.5 Inches) soldered to the side of the chassis. It is a 1000V .012uf. Can a 630v of same value replace that? Or where can I get a replacement?
:A common .01 uf at 630V will be fine. I would install a fuse after the power switch and a polarized plug.. make sure you switch the hot side of the A.C. for safety.
::3. Do Filter caps C17 and C36 negative side connect to chassis ground? While C33 to the center tap of the TX?
::Thanks for any help you can provide.
::Bob E
:Yes, correct. A good source of caps. is justradios.com in Canada. He is reliable and easy to deal with. John
