Thanks!
Bill
6227 is same as E80L. Some information can be found here.
http://tdsl.duncanamps.com/show.php?des=6227
It's said to be similar to 6M5 which I believe is used in Australia?
:Hello, I have a Hickok 6000 and 6000A tube tester, however, a 6227 tube does not appear on the roll charts. Is there a way to test this tube on one of these testers? You can either reply to this posting or email me directly at OldRadios@AOL.COM
:Thanks!
:Bill
Thanks!
Bill
:Bill
: 6227 is same as E80L. Some information can be found here.
: http://tdsl.duncanamps.com/show.php?des=6227
: It's said to be similar to 6M5 which I believe is used in Australia?
::Hello, I have a Hickok 6000 and 6000A tube tester, however, a 6227 tube does not appear on the roll charts. Is there a way to test this tube on one of these testers? You can either reply to this posting or email me directly at OldRadios@AOL.COM
::Thanks!
::Bill
It seems the 6M5 tube HAS been suggested as being problematic in its past. (Considering that your industrial numbered version might not have been a ruggedized upgrade ?) It might be further worthwhile to take a read on this info at this site for their resultant end solutions @. (Ending up down at the 6GW8/ECL86 info.)
::Bill :::Hello, I have a Hickok 6000 and 6000A tube tester, however, a 6227 tube does not appear on the roll charts. Is there a way to test this tube on one of these testers? You can either reply to this posting or email me directly at OldRadios@AOL.COM
:I am not able to locate the E80L or 6M5 tubes on my tester roll charts either. Would someone be able to provide me with the settings for testing the 6227 ?
:Thanks!
:Bill
:: 6227 is same as E80L. Some information can be found here.
:: http://tdsl.duncanamps.com/show.php?des=6227
:: It's said to be similar to 6M5 which I believe is used in Australia?
:::Thanks!
:::Bill
