Its even a Ray-dee-ohhh Shack-i-mus item. |
1000uf at 300 volts would be about the size of your fist.
Sir Edd,
Thank You so much. I followed your advice and the unit is now working. This is not the first time that your advice helped me so again, Thank You
Bill
:Sir . . . . . .Bill
:Nope, definitely NOT a 300VDC rating, as the highest voltage used on that set would be its +90 volts Bee-Plus.
:And that 1000 ufd at 3VDC is correct for that electrolytic value , with it being associated as the filtering medium for the 1.5 VDC A supply for the sets filaments.
:And that high of a capacitance even
:at that low of a voltage rating would have been a bit of a challenge back in those years.
:Nowadays, that value is as common as dirt in its use in solid-i-mus state-i-fied work in these current times, but more commonly found in 6 /12 / 16VDC ratings on its voltage spec.
:Its even a Ray-dee-ohhh Shack-i-mus item.
:I have a question regarding a Sentinel Radio. It is an old Battery type Model 118B. I have restored the radio and it works perfectly. I also got a Sentinel HiLine battery eliminator that I am still working on. It has a 6P5GT Tube and several electrolytic capacitors in it. Three of the caps are labeled Mallory Type EP 1000 MFD 3 V. I am assuming that this means 1000mfd @ 3 volts. But It does not make sense. Could this mean 300 volts instead. Also where does one get 1000MFD caps at 3 volts or even 300 volts for that matter? AES does not offer anything in this range. Any help or direction will be greatly appreciated.
:1000uf at 300 volts would be about the size of your fist.
:Johnnysan-
1000 uF @ 300 Volts would be excellent for killing things, too.
