Grundig 4010GW uses 2 UL11 and 5010 uses two UL12, so the schematics are the same ? Can any brother share the 4010GW schematics? I am pretty new with tubes. Thanks for help.
regards
Jimmy
:Sirs
:Grundig 4010GW uses 2 UL11 and 5010 uses two UL12, so the schematics are the same ? Can any brother share the 4010GW schematics? I am pretty new with tubes. Thanks for help.
:regards
:Jimmy
. . . . . GRUNDIG 5010 SCHEMATIC . . . . . ![]() |
Sirs Grundig 4010GW uses 2 UL11 and 5010 uses two UL12, so the schematics are the same ? Can any brother share the 4010GW schematics? I am pretty new with tubes. Thanks for help.
Any expert who has the Grunddig 4010GW schem, kindly share to my email shichaolin@hotmail.com ,appreciate in advance.
Jimmy
regards
: : : ![]() : : : : : : : :Sir Jimmy . . . . . : : :This should give you adequate info on troubleshooting that GRUNDIG unit, with the most difference just being in the A.F. output stages. : : : : :73's de Edd : : : ![]() : |
: : : : . . . . . GRUNDIG 5010 SCHEMATIC . . . . . : : : ![]() : : : : : |
