SCHEMATIC FOR PHILCO 42355 RADIO
6/30/2010 11:05:24 AMBILL AMBROSIA
I THINK THAT THE CAPS ARE BAD AND I WANT TO REPLACE THEM. CAN YOU HELP?
6/30/2010 11:22:06 AMNorm Leal
Bill
Here is technical information.
http://www.nostalgiaair.org/PagesByModel/525/M0013525.pdf
:I THINK THAT THE CAPS ARE BAD AND I WANT TO REPLACE THEM. CAN YOU HELP?
6/30/2010 3:30:54 PMDoug Criner
Is the radio presently working at all? If not, I wouldn't advise replacing the caps yet, except for the power supply filter caps. You should troubleshoot first, and get it working after a fashion. Then after each cap is replaced, check to make sure the radio still works.
Otherwise, you'll likely wind up with a radio that still doesn't work, and it'll be difficult to determine if you made a mistake in the recapping.
