:Greetings,
:I am searching for a Heathkit Ig-102 tuning knob. I finally purchased a signal generator (not the one in the photo), it has to be re-built. The dial pointer has browned and above all the tuning knob is stripped and I can not tighten the 8-32 set screw on to the shaft. If anyone has one and could part with the dial pointer but more importantly the knob itself please contact my e-mail address above. I will pay for it.
:Thank you,
:Vinny A.
:Vinny,
:If the set screw is the only problem, drill the hole for a #10-32 screw and re-tap (new threads)
:marv
::Greetings,
::I am searching for a Heathkit Ig-102 tuning knob. I finally purchased a signal generator (not the one in the photo), it has to be re-built. The dial pointer has browned and above all the tuning knob is stripped and I can not tighten the 8-32 set screw on to the shaft. If anyone has one and could part with the dial pointer but more importantly the knob itself please contact my e-mail address above. I will pay for it.
::Thank you,
::Vinny A.
:Marv, I have not done that before. What size drill bit is needed for a 10-32? Do you need a tool that re-threads or will the screw make its own threads or crack the knob from inside?
:Thanks,
:Vinny A.
::Vinny,
::If the set screw is the only problem, drill the hole for a #10-32 screw and re-tap (new threads)
::marv
:::Greetings,
:::I am searching for a Heathkit Ig-102 tuning knob. I finally purchased a signal generator (not the one in the photo), it has to be re-built. The dial pointer has browned and above all the tuning knob is stripped and I can not tighten the 8-32 set screw on to the shaft. If anyone has one and could part with the dial pointer but more importantly the knob itself please contact my e-mail address above. I will pay for it.
:::Thank you,
:::Vinny A.
A Shiny New Pointer: Thassit . . . .did you get the point(er) ? |
FONT SIZE=4 FACE="Comic Sans MS"COLOR=00ff00> FONT SIZE=4 FACE="Comic Sans MS"COLOR=ff00ff>
:Vinny,
:For a 10-32 screw use a #21 (0.159") drill bit, and yes, you'll need a 10-32 tap from a hardware store. You might find a 10-32 self tapping screw, but won't be a set screw. Another option is to fill the hole with JB Weld epoxy, and re-tap for the 8-32. You could actually smear a little epoxy around, inside the threads, wait a few minutes, thread in a normal 8-32 screw, then back it out. Let the epoxy dry, then insert the set screw. Again a self tapping 8-32 screw from the hardware will cut new threads in the epoxy, then use the regular 8-32 set screw.
:marv
::Marv, I have not done that before. What size drill bit is needed for a 10-32? Do you need a tool that re-threads or will the screw make its own threads or crack the knob from inside?
::Thanks,
::Vinny A.
FONT SIZE=4 FACE="Comic Sans MS"COLOR=00ff00>::
:::Vinny,
:::If the set screw is the only problem, drill the hole for a #10-32 screw and re-tap (new threads)
:::marv
::::Greetings,
::::I am searching for a Heathkit Ig-102 tuning knob. I finally purchased a signal generator (not the one in the photo), it has to be re-built. The dial pointer has browned and above all the tuning knob is stripped and I can not tighten the 8-32 set screw on to the shaft. If anyone has one and could part with the dial pointer but more importantly the knob itself please contact my e-mail address above. I will pay for it.
::::Thank you,
::::Vinny A.
The knob was drilled and re-tapped for a 10/32 and worked great, it does continue to turn when the dial and tuner reach the end of the road. It does leave a scratch on the tuner shaft if you keep on turning it. However, I broke the plastic dial so the job is on hold and I am unable to see the turns ratio of the knob to dial.(not terrible because the generator was free). I bought another one and I am waiting for it to come. I will respond when it does come.
Thank you,
Vinny A.
:Warren, great idea! I will try that, I wonder how difficult it will be to try and drill something small, metal, and round.
:Thank you,
:Vinny A.
:Marv, thank you.
:I was setting up to either drill or grind the shaft.
:I detoured and tried to clean the dial pointer which was brown. Then came a snap, and the dial pointer broke off into a couple of pieces. Silence for 10 minutes.
:Thanks anyway,
:Vinny A.
This is completely normal for this signal generator.
Gary
:Greetings,
:I took the knob to a hardware store and the worker drilled and re-tapped the knob hole for 10/32 and just put a machine screw in the place for a set screw which de did not have. It sat well on the tuning shaft and turned the dial. However, when the dial and tuning condenser stopped turning in each direction, the knob and screw kept turning as if it was sliding on the tuning shaft.
:I am wondering if there is a part missing in the knob which puts pressure on the shaft and keeps the screw from continuously turning. Constantly the screw will have to be tightened as it wears down the metal of the tuning shaft.
:I also tried a similar knob with a 8/.32 setscrew in it that did the same thing.
:Does any one have this issue with their generator or any suggestions.
:Vinny A.
