SiLvErToNe 6136
6/26/2010 12:14:33 PMChris
Hello All. I just aquired an awesome Silvertone 6136 chassis with push/pull 6V6.My first P.P output radio other than P.P. 45 or 71. triodes. This one should be LOUD and will sound awesome on shortwave! will use a PM speaker(with resistor) and build an ART DECO ported cabinet for it.Anyways does anyone here have one of these and any info on BIAS CELL rejuvination ? On the schematic it shows how to insert phono plug into the circuit.Is this meant for a shorting type jack?Thanks for info
6/26/2010 12:43:43 PMChris
:Hello All. I just aquired an awesome Silvertone 6136 chassis with push/pull 6V6.My first P.P output radio other than P.P. 45 or 71. triodes. This one should be LOUD and will sound awesome on shortwave! will use a PM speaker(with resistor) and build an ART DECO ported cabinet for it.Anyways does anyone here have one of these and any info on BIAS CELL rejuvination ? On the schematic it shows how to insert phono plug into the circuit.Is this meant for a shorting type jack?Thanks for info
:I am also wondering what the 100 ohm resistors on the plates of the 6V6's are for.Are they to reduce voltage or for tone or stability??Thanks for info
6/28/2010 7:43:12 AMChris
::Hello All. I just aquired an awesome Silvertone 6136 chassis with push/pull 6V6.My first P.P output radio other than P.P. 45 or 71. triodes. This one should be LOUD and will sound awesome on shortwave! will use a PM speaker(with resistor) and build an ART DECO ported cabinet for it.Anyways does anyone here have one of these and any info on BIAS CELL rejuvination ? On the schematic it shows how to insert phono plug into the circuit.Is this meant for a shorting type jack?Thanks for info
::I am also wondering what the 100 ohm resistors on the plates of the 6V6's are for.Are they to reduce voltage or for tone or stability??Thanks for info
:One more question. Can I use 2 8000 0hm single ended transformers with the primaries tied together for use as a push/pull transformer(at least temporarily)?IPAddress: ***.55.36.118
6/28/2010 8:42:21 AMEdd
Sir Chris . . . . . .
Wont's it sounds guds on plain ole AM's broadcasts also ?
6Q7 1st grid biasing solutions?
Decisions . . . decisions . . . decisions ?
1 . . .
A MICRO entry slit into the old cell casing with the edge "touch" of a cutting wheel in a Dremel tool followed with an insulin syringe injection of distilled water and a hot glue resealing of casing . . hoping for . . it's alive . . . IT'S ALIVE . . . IT'S ALIVE !
2 . . .
Replacement of ye olde tymes cell with modern generation button cell.
3 . . .
Replacement of cell with series coupling capacitor and use a 10 meg 1st grid resistor to ground, placed at the grid side of the coupling capacitor.
4 . . .
Stage self biasing via the use of a cathode resistor on the 'Q7.
The phono plug switching action is merely passing the detected audio right on thru to the high side of the volume control with no plug inserted. With a plug in place, the incoming radio audio is disconnected and the phono cart input is routed to the high end of the vol-you-me control instead. The contacts on the female phone receptacle of the radio are doing the switching actions.
Its a HF stability /unwanted parasitic RF oscillation suppression . . . thang . . . (technique).
tied together (in series)
Yup . . . that circuitry do be very forgiving, just as long as your 50/50 odds, doesn't end up getting them cross phased.
:::I am also wondering what the 100 ohm resistors on the plates of the 6V6's are for.Are they to reduce voltage or for tone or stability??Thanks for info
::One more question. Can I use 2 8000 0hm single ended transformers with the primaries tied together for use as a push/pull transformer(at least temporarily)?IPAddress: ***.55.36.118
6/28/2010 9:09:46 AMChris
:Thanks Edd!!This is very helpful!!Oh yes I love AM but sometimes I love listening to the weird airplane ,buzz saw pHaSe ShIfTiNg sounds and other noises on shortwave ,I am very ECCENTRIC , and also to hear the foreign broadcasts ,and CBC also has a shortwave station :
:Sir Chris . . . . . .
:This one should be LOUD and will sound awesome on shortwave!
:Wont's it sounds guds on plain ole AM's broadcasts also ?
:any info on BIAS CELL rejuvination
:6Q7 1st grid biasing solutions?
:Decisions . . . decisions . . . decisions ?
:1 . . .
:A MICRO entry slit into the old cell casing with the edge "touch" of a cutting wheel in a Dremel tool followed with an insulin syringe injection of distilled water and a hot glue resealing of casing . . hoping for . . it's alive . . . IT'S ALIVE . . . IT'S ALIVE !
:2 . . .
:Replacement of ye olde tymes cell with modern generation button cell.
:3 . . .
:Replacement of cell with series coupling capacitor and use a 10 meg 1st grid resistor to ground, placed at the grid side of the coupling capacitor.
:4 . . .
:Stage self biasing via the use of a cathode resistor on the 'Q7.
:On the schematic it shows how to insert phono plug into the circuit.Is this meant for a shorting type jack?
:The phono plug switching action is merely passing the detected audio right on thru to the high side of the volume control with no plug inserted. With a plug in place, the incoming radio audio is disconnected and the phono cart input is routed to the high end of the vol-you-me control instead. The contacts on the female phone receptacle of the radio are doing the switching actions.
:Its a HF stability /unwanted parasitic RF oscillation suppression . . . thang . . . (technique).
:tied together (in series)
:Yup . . . that circuitry do be very forgiving, just as long as your 50/50 odds, doesn't end up getting them cross phased.
::::I am also wondering what the 100 ohm resistors on the plates of the 6V6's are for.Are they to reduce voltage or for tone or stability??Thanks for info
:::One more question. Can I use 2 8000 0hm single ended transformers with the primaries tied together for use as a push/pull transformer(at least temporarily)?IPAddress: ***.55.36.118
