Gulbansen (model #???) need a schematic..help please
6/22/2010 7:11:46 PMGeorge
Hi all I just picked up a Gulbransen chairside radio with no model # on it. I can not find a schematic to match this tube line up...Help please... Radio has 3 224s, 227, 2 245s, and a 280 tube. Tube sockets are marked w/ these numbers...I am guessing it is 1930-33. It has the lovely tar cap blocks and I need to know the cap values...Thank you for any help.
6/22/2010 8:14:46 PMNorm Leal
George
Look through the schematic which can be found here:
http://www.nostalgiaair.org/Resources/177/T0000177.htm
Check Model 160..
:Hi all I just picked up a Gulbransen chairside radio with no model # on it. I can not find a schematic to match this tube line up...Help please... Radio has 3 224s, 227, 2 245s, and a 280 tube. Tube sockets are marked w/ these numbers...I am guessing it is 1930-33. It has the lovely tar cap blocks and I need to know the cap values...Thank you for any help.
6/22/2010 8:34:42 PMGeorge to Norm
I look through all of the scheamtics on here and the 160 modle is close but has a extra 27 tube...I am not expert so I am kind-a looking for the exact schematic...If i use the 160 model schematic I will "get lost" with all the extra wires and such
:George
: Look through the schematic which can be found here:
:http://www.nostalgiaair.org/Resources/177/T0000177.htm
: Check Model 160..
::Hi all I just picked up a Gulbransen chairside radio with no model # on it. I can not find a schematic to match this tube line up...Help please... Radio has 3 224s, 227, 2 245s, and a 280 tube. Tube sockets are marked w/ these numbers...I am guessing it is 1930-33. It has the lovely tar cap blocks and I need to know the cap values...Thank you for any help.
6/22/2010 9:25:55 PMNorm Leal
George
We have Rider schematics for older radios. Other than that not much is available.
Pin #2 on all tubes is plate. This pin should be positive. Pin #3 on the 24 is screen and will also be positive but less than pin #2. Would expect voltage in the 100-250 volt range. Missing voltage will stop the radio from operating.
:I look through all of the scheamtics on here and the 160 modle is close but has a extra 27 tube...I am not expert so I am kind-a looking for the exact schematic...If i use the 160 model schematic I will "get lost" with all the extra wires and such
::George
:: Look through the schematic which can be found here:
::http://www.nostalgiaair.org/Resources/177/T0000177.htm
:: Check Model 160..
:::Hi all I just picked up a Gulbransen chairside radio with no model # on it. I can not find a schematic to match this tube line up...Help please... Radio has 3 224s, 227, 2 245s, and a 280 tube. Tube sockets are marked w/ these numbers...I am guessing it is 1930-33. It has the lovely tar cap blocks and I need to know the cap values...Thank you for any help.
6/22/2010 9:26:05 PMJohn
::George
Look through radiomuseum.org. Their listing does not show one that matches your tube lineup but lists two with little description. It shows a model 535 7 tube console with no other info. & a model M-5-A1 large table model with a picture. Are you looking for a true chairside console? John
6/22/2010 10:12:19 PMGeorge
No.. I am just looking for a schematic so I can restore chassis.. This dam thing has a cap bock with just wires comming out of it to various components.
::I look through all of the scheamtics on here and the 160 modle is close but has a extra 27 tube...I am not expert so I am kind-a looking for the exact schematic...If i use the 160 model schematic I will "get lost" with all the extra wires and such
:::George
::: Look through the schematic which can be found here:
:::http://www.nostalgiaair.org/Resources/177/T0000177.htm
::: Check Model 160..
::::Hi all I just picked up a Gulbransen chairside radio with no model # on it. I can not find a schematic to match this tube line up...Help please... Radio has 3 224s, 227, 2 245s, and a 280 tube. Tube sockets are marked w/ these numbers...I am guessing it is 1930-33. It has the lovely tar cap blocks and I need to know the cap values...Thank you for any help.
:George,
:Look through radiomuseum.org. Their listing does not show one that matches your tube lineup but lists two with little description. It shows a model 535 7 tube console with no other info. & a model M-5-A1 large table model with a picture. Are you looking for a true chairside console? John
6/23/2010 1:01:50 AMKen K.
6/23/2010 1:57:52 AMGeorge...S.O.B. THATS IT!!!
Ohhh wow thanks Ken ...I learned that Wells Gardner made the chassis but did not know what model...THANKS THANKS....god deal!!!
