Source for small isolation transformers
6/14/2010 10:10:56 AMBrian
Anyone have sources (Canada or US) for small isolation transformers for building B eliminators?
6/14/2010 10:48:29 AMLewis
:Anyone have sources (Canada or US) for small isolation transformers for building B eliminators?
I fished two 120 Volt to 6 Volt @20 Amps out of the trash when we reworked a project at work. So, I hooked them up back to back and have an isolation transformer that is rated at 120 Watts, I have 3000 Volts of isolation. A little overkill, I suppose, but I fished the whole project out of the trash, including the case, switch, indicator lamp, circuit breaker, cord and socket for nothing.
You might try a couple of Radio Shack transformers wired back to back or something like that for a "B" eliminator. I would have made mine smaller, but I kinda liked the idea or doing it all strickly from the trash barrel.
6/14/2010 9:53:04 PMBill VA
AES has 35 VA rating Triad P/N P-TN-51X, small enough?
Bii
