1 meg is the standard modern value. Although not necessary you might like to use a 1 or 2 watt resistor. They are larger and would look better in an old radio.
:I know this has been discusses on numerous occasions but I have worked myself into a lather trying to make the conversion from the old style dogbone resisters to the newer terminolgy. I broke a resister with a brown body with a black end. The schematic calles it a 1 meg. What is the modern value? I cant seem to get it through my thick skull.
:Thanks,
:Jon.
Is that 1 million?
:::I know this has been discusses on numerous occasions but I have worked myself into a lather trying to make the conversion from the old style dogbone resisters to the newer terminolgy. I broke a resister with a brown body with a black end. The schematic calles it a 1 meg. What is the modern value? I cant seem to get it through my thick skull.
:::Thanks,
:::Jon.
:::Hi Jon
::: 1 meg is the standard modern value. Although not necessary you might like to use a 1 or 2 watt resistor. They are larger and would look better in an old radio.
:Is that 1 million?
::::I know this has been discusses on numerous occasions but I have worked myself into a lather trying to make the conversion from the old style dogbone resisters to the newer terminolgy. I broke a resister with a brown body with a black end. The schematic calles it a 1 meg. What is the modern value? I cant seem to get it through my thick skull.
::::Thanks,
::::Jon.
