Kolster radio model 6J
6/8/2010 7:58:45 PMbud
I have this wonderfull radio in great condition, all in working condition except for the speaker. can you suggest a way to connect a modern speaker as a replacement. Thanks
6/8/2010 8:24:44 PMNorm Leal
Hi Bud
Kolster 6J requires a high impedance speaker. You can use a modern speaker with output transformer. Output transformer value isn't critical. One used with a 6V6, 6F6, 41, 42 etc will work.
http://www.nostalgiaair.org/PagesByModel/082/M0040082.pdf
:I have this wonderfull radio in great condition, all in working condition except for the speaker. can you suggest a way to connect a modern speaker as a replacement. Thanks
6/9/2010 2:11:05 PMGeorge...caps??
If the block of caps have not been replaced in this radio I would highly suggest doing so...The large "book" caps will be or go bad...If it is something you are going to actually use for short periods of time I would suggest doing so....
6/9/2010 5:30:05 PMBud
:thankIf the block of caps have not been replaced in this radio I would highly suggest doing so...The large "book" caps will be or go bad...If it is something you are going to actually use for short periods of time I would suggest doing so....
::I have this wonderfull radio in great condition, all in working condition except for the speaker. can you suggest a way to connect a modern speaker as a replacement. Thanks
