Thanks in advance
Select the channel that is not in use in your area (most often a choice between channel 3 and channel 4) Set the output level of the generator to the lowest level before you get noise on the screen.
From there, your basic steps are:
-adjust ion trap if equipped, and deguass the set.
-let both the set and the generator operate for about 20 minutes before you begin adjustments.
-Verify that B+ voltage at the anode is less than 25KV as described in TV cabinet.
-Adjusting purity (even white across the screen)these are the small magnetic rings that are behind the yoke towards the pin end of the tube.
-adjusting the deflection coil magnets for even coverage across the screen
-setting your color drives by shorting one gun at a time through a 10K resistor and matching certain color bars depending on which gun is shorted, how many bars your generator produces, and how the manufacturer set up the color bars. *Most often you are matching two bars on either end, or the center depending on which gun is shorted.
-Converging the guns to focus the three color beams to produce white dots in the dot pattern setting.
You usually do not get all guns converged to a point where all points are white with no color shadows (perfect convergence), but that is the goal. Usually settling on a best average compromise.
Best time to do this is at night.
Basically, the steps will always be the same within a certain degree, but how each step is achieved can vary with the set manufacturer, or the convergence equipment. Otherwise the steps in a book printed in 1956 are just as valid as one printed in 1986.
: Looking for manual or any tips on the operation of this unit
: Thanks in advance
