atwater kent model 46
7/5/2001 4:31:20 PMWilliam c Pemberton
I need to know the tube layout for above model and their numbers.Also where can i get a schematic and a continuity test table and chart.I have above model and can find nothing to help me.Any help would be appreciated
Bill
7/5/2001 6:35:50 PMNorm Leal
Hi Bill
The tube layout is all 01A's. 01A's may be marked UX201A, CX301A or other number. All will have 01A within the number. You can use a 71A (171A) in the last socket on the right with -22 1/2 volts "C" bias. The Model 49 is same as 33 except for slight difference in front panel color. Schematic and other information will be available here on nostalgiaair.
http://ww3.nostalgiaair.org/schematics/A-K/A-K_3-6.gif
: I need to know the tube layout for above model and their numbers.Also where can i get a schematic and a continuity test table and chart.I have above model and can find nothing to help me.Any help would be appreciated
: Bill
7/5/2001 9:31:04 PMNorm Leal
Hi Bill
You are right. I've been talking to someone else about a Model 49. I'll answer you by email.
: Hi Bill
: The tube layout is all 01A's. 01A's may be marked UX201A, CX301A or other number. All will have 01A within the number. You can use a 71A (171A) in the last socket on the right with -22 1/2 volts "C" bias. The Model 49 is same as 33 except for slight difference in front panel color. Schematic and other information will be available here on nostalgiaair.
: http://ww3.nostalgiaair.org/schematics/A-K/A-K_3-6.gif
: Norm
: : I need to know the tube layout for above model and their numbers.Also where can i get a schematic and a continuity test table and chart.I have above model and can find nothing to help me.Any help would be appreciated
: : Bill
7/5/2001 9:32:35 PMNorm Leal
Hi Bill
You are right. I was talking to someone else about a Model 49. I'll answer you by email.
: Hi Bill
: Norm
: : Bill
2/27/2002 10:25:49 PMDavid Salinsky
Does anyone know the exact speaker model for the Model 46.
: : Hi Bill
: : The tube layout is all 01A's. 01A's may be marked UX201A, CX301A or other number. All will have 01A within the number. You can use a 71A (171A) in the last socket on the right with -22 1/2 volts "C" bias. The Model 49 is same as 33 except for slight difference in front panel color. Schematic and other information will be available here on nostalgiaair.
: : http://ww3.nostalgiaair.org/schematics/A-K/A-K_3-6.gif
: : Norm
: : : I need to know the tube layout for above model and their numbers.Also where can i get a schematic and a continuity test table and chart.I have above model and can find nothing to help me.Any help would be appreciated
: : : Bill
